Came here to hopefully find knowledgeable folks. Just purchased a used Dixon ZTR. Trying to find the model and such. Only info I can find so far is the serial number. Any advice?
Service and Support | Dixon Contact Dixon by email with information you have, ask them to email all manuals & wiring diagram for your mower, they should more than happy to assist you.
I have one that is serial # 45-011593 so probably a 2001...yours maybe a 2002
My cup holder is behind the cutting lever and handle to cutting lever may be different.
My gas cap is in the middle of the foot rest.
Another thing I just found, if it is a 2002
The “Dapco” oil drain valve is located on the left
side of the engine crankcase (Model 4515B &
4518K) and on the right side of the engine
crankcase (Model 4516K).
Mine is a Dixon ZTR 4515B
Model decal is located in a recessed spot in front and below the ignition switch about 4-5 in square
Go to bottom of page and find 4000 series and look at the owner's manual and see if the 2002 ZTR4515B is not yours Dixon Owners Manuals
