Cub Wanter
Okay, entire story, here we go.. Craftsman lt2000 of 15 years with a Briggs intek I bought (new) 3 years ago, ran beautifully up till last week when it decided to just not start.
I got right to diagnosing, worked my way to the carb when I borrowed a friend's chinese ebay carb.. finally it started (hooray) so I took my Ruixing unit carefully apart and cleaned, in which 3 years of 100% gas yielded a new looking everything in the inside...
Upon reassembly I plugged in the fuel solenoid by itself and discovered it faulted (as borat would say "great success") So no problem... I order a new solenoid and gasket for installation.
NOW.... my issue is a tough cold start (like a solid 10 Mississippis to fire up) and aggravating surge when I push throttle to "blade" level, with continued surge with the blade engaged.
I've gone nearly nanners over this nonsense and am ready to set this thing on fire and make smores off it. Then piss on the ashes... Only detail I can "help" with diagnoses is if I remove the air filter and choke the intake with my hand for a few seconds, it clears up the surge for a bit. Everything seems to be in order, what could I possibly be missing?
Any tips or info would be greatly appreciated.. Thank you
