Jeff77x
- May 18, 2020
- Threads
- 1
- 3
I have a 2013 Craftsman LT2000,, model 247.288853. I just finished replacing both the long and the short drive belts. Took me a couple of hours, because I didn’t take pictures and had a hard time reassembling the tension mechanism with the two pulleys. Once done, I took it for a test drive. The accelerator pedal is stiff, and as soon as I put it in forward it started moving on its own. Pressing the brake wouldn’t stop it either. Is there any adjustment that I can make to fix this? Only thing I see is some threads on the end of the rod connecting the accelerator pedal to the tensioner. Any help is greatly appreciated. Thank you.
