I put a new carburetor (P/N 632795A) on a Lawn Boy 10313. I don't have the engine model, but I'm guessing it's a Tecumseh 5.5 hp. After priming a few times, it started right up, then died a few seconds later. Primed again, with same results. Then I kept priming as it ran, and it ran as long as I was priming. Then I found that if I just pushed the primer bulb in and held it in, it would run without stopping but after releasing the primer, it would shut off again.
I'm thinking it may have something wrong with the normal flow of gas.
Can anyone give me an idea of what it could be? Thanks for your help.
RogerTM
RogerTM
