- Nov 29, 2014
- Threads
- 64
- 24,705
Customer came in yesterday with this starter he says came off a Briggs.
It is totally unfamiliar to me and searching using the numbers stamped into the top bracket ( 9412295M) came up with nothing
Do any of you with more experience than me recognise it ?
The problem is some one has tried to undo the + cable nut & broken the housing so there is nothing inside to anchor the + terminal bolt.
The customer dennied touching it however when opened there were no + brushes, just the 2 ground ones that are riveted to the alloy end cap , one missing the spring and the clamping bolt head was so rounded I had to use a stud extractor to remove it.
Customer also reckons he had started the mower a few times using this starter ( really ).
I hate customers than BS to me but just the same it needs to be fixed.
I have a good supply of brushes & brush holders but none will fit inside the current end cap and the flat steel ones will not clamp onto the body
It is a 16 tooth pinion
Thanks greatly
Thanks greatly
