I have a snapper RER 3008s that a 'skipped' tenant left behind. The engine will run by squirting gas in the intake,so it appears worth saving. It appears that the previous owner had the carb linkage removed and improperly installed,and I am in need of a good picture to get it hooked up to the governor leg,throttle, and choke--pretty much everything to do with the throttle control linkage.
The motor numbers are as follows--first the top line
MODEL TYPE CODE
Then the numbers
190702 2161 01 8604110
Any help appreciated,and I will reply so you guys know how it goes for this machine.
MODEL TYPE CODE
Then the numbers
