Need help with Toro identification and carburetor clean
netrate
  • / Need help with Toro identification and carburetor clean
I have Toro, but after looking at it from several angles, I cannot seem to find the model or serial number for it. I have included a host of pictures to see if anyone can identify it.
I think it was for commercial use, and there is a scratched out number "Something-something-ZERO" on the front of it.
Once identified, is this carb difficult to clean? So far, getting the bolts off hasn't been easy...
You haven’t look everywhere. Look under the sheet metal cover on the handle. Should find the model number and serial number. Suzuki engine, not difficult to clean, get a rebuild kit first, might not be available in your area.
netrate
Unfortunately, there is nothing under there. I took a pic to be sure.
Can you think of anywhere else maybe?
netrate
Well, I have had no luck finding the model/serial number for this. I have checked underneath, the bag, the underpanels - everywhere a layman would look, but I can't seem to figure this one out.
It’s not even three full days, you low on patience, like we should jump for you? Do you have any ideas how many models Toro built using a Suzuki engine? If it is a two cycle engine try model 20581. If it is a four cycle engine try model 26622. The engine Is Suzuki, so try googling Toro mowers with either 2 or 4 cycle engines, which ever you have.
netrate
I didn't think I was being impatient, I was just stating that I wasn't being idle and I couldn't seem to find the model number. I didn't want anyone to think I didn't put in some effort is all. Sorry if it came across as such.
