Need help with Recharge G2 Electric Mower
waynuj
I have a Recharge G2 Electric Mower. When I pressed the accelerator, the green light blinking and the unit is not moving. When I took my foot off from accelerator, the green link turned solid. would you please advice how to troubleshoot and fix the issue. thank you so much in advance.
KrashnKraka
Using a analog multimeter connect across the battery bank
(red to red black to black on output leads).
Depress the accelerator and watch the voltage drop.
It's a guess but more than 10% of drop from stable
voltage would be of concern.
These machines have fuzzy logic boxes monitoring all
electrical inputs/outputs. IDEALLY there will be an error code
displayed. No sign of such?
