armadilloholejumper
- Oct 8, 2013
- 1
- 3
I am new to the forum and hope ya'll can help. I have a exmark quest s series and it runs and cuts great. lately when I shut off the engine when it is hot it will not start back up. It acts like the starter is dragging or the battery is low, it will barely turn the flywheel. After it sits for a while it will crank up just fine and run, you can kill it and crank it over and over again as many times as you want and it cranks perfectly, and the motor is still just as hot as it was 5 minutes earlier when it wouldnt crank. It also cranks fine when its cold. its got me stumped.
