Allergic2Grass
Found a 225 at a flea market. Wasn't in a usuable state. Didn't have a spark plug,no head,covered in oil,spark arrestor full of carbon,no air filter and cover and he didn't know what was wrong with it. I offered him 30 bucks and he said deal.
The problems and what I've done
(Using TruFuel 50:1)
1.Bought spark plug and it sputtered for a half second then just dies...I describe it as the sputter before you go to choke 2 on a trimmer and start it again.
2. Changed fuel lines. Ran a second longer but still died.
3.Took carb apart and cleaned it with carb cleaner and replaced all gaskets and the floater.
After cleaning the carb I can get it to stay running with the choke lever up, and am able to barely move it unlike before and keep it running. Of course it dies when I pull lever down
Also,even with the new kit I am seeing air in my yellow fuel line. And to keep it running I have to turn it to one side basically pointing the gas cap down to keep it running. The lines and primer bulb are new so that one has me confused.
What steps should I try next?
Thanks for any and all help
