Gearjammer
If you suspect the solenoid, you could either jump across the posts with a screwdriver while the switch is in the on position and everything else is ready to start(you're in the seat, mower clutch off, brake on, etc.) or you could jump from the battery to the starter which would tell you if it was the starter instead of the solenoid or loose connections somewhere. Again, good luck. Gearjammer
