Need help getting Model #
Duffer72
Have a Murray Lawn tractor gear transmission ,42" cut with b & S 14hp IC twin on it code on engine is 9303305 so I assume it is either a 93 or 94 production lawn tractor. the id tag is gone just a scrap or 2 left of it no #'s, It has the hood that hinges towards the steering wheel on a piano hinge. A good cust wants this unit running, problem being the wiring harness is completely gone, along with other parts, I need a model # so I can get a wiriing diagram and parts breakout for it, just spent 3 hrs going thru what I have of old murray micro fiche with no luck, hoping someone has one like this
and can give me the model # , it is similar to a model 38221A which is the closest I found to it.
Thanks for any help on this
Dangeroustoys56
I have a 90 LT murray like that - mines a single cylender 12HP briggs with a 38" deck tho - if it still has the chassis tag, ill post it here .
Update: i checked the tractor this morning- my data tag is missing.....
