Need help adjusting throttle using tach, does GXV160 have 1 spark per 1 RPM?
mikeypizano
  • / Need help adjusting throttle using tach, does GXV160 have 1 spark per 1 RPM?
Trying to set my throttle speed, and I picked up a DTI Fast Tach wireless tachometer. I can get it to 2000RPM but any more and engine surges. My tach is set at default to 1 spark per 1 rpm.
Jack17
Maybe your Honda has "anti-wasted spark" sensor? If so, then 1 spark per two revs.
mikeypizano
Is Robert around? Maybe he can find out for me.
SeniorCitizen
Are we now going to be required to learn a third language?
robert@honda
Honda mower engines do indeed have a 'wasted spark' design..configure your tach for a single-cylinder engine and it should be fine. When fitted to a mower chassis, the GXV160 should be dialed in at 3,100 +/-50 RPM
mikeypizano
https://www.amazon.com/Wireless-han...&qid=1487181580&sr=8-1&keywords=dti+fast+tach
That is the tach that I got. I can't get it to go past 2000RPM, tach is set by default at 360*, or 1 pulse per 1 revolution, which to me, being at 2000, it seems much faster than that, so I wonder if this tach is bad...
Is it 3100 with blade on and no load or blade on with full load?
robert@honda
mikeypizano
Try setting it @ 180 and see what you get.
3,100 is with the blade engaged.
I am going to try testing it on a diff engine tomorrow and see what it says. 180 would be 2 spark per 1 rev
