MZ zero turn hyd oil question
HarleyUltra
I have a zero turn MZ7227 zero turn from around 2010. I can't anywhere in the manual what the oil capacity of the hydraulic drive when doing an oil and filter change. Can any help me with this?
Thanks
Not in the Husqvarna manual
Try the hydro makers manuals .
7394
are yours the EZ 2100 or 2200 ?
7394
OK, leaves me out.. Sorry.
hlw49
It is not in the Husqvarna owners manual or parts manual.Was able to find this. Still does give capacity but close.
Place an oil drain pan with a two gallon
capacity beneath the oil filter. Remove the
oil filter from the pump.
2.
After the oil has drained, wipe the filter
base surface off and apply a film of new oil
to the gasket of the new replacement filter
