BKBrown
- May 5, 2010
- Threads
- 15
- 1,415
OK - Here is one for you people -- Neighbor has a 30" Snapper with the 12.5 Briggs Intec. I had cleaned up all the grease and oil and replaced the spindle (bearings were bad) - put the battery back in (took it out and gas tank off to do the work) and hooked up + and - exactly where they had been for years. Everything seemed fine and J.R. used the mower for a couple hours (happy with new spindle and sharp blade) stopped to get some lunch - came out and found Ground - cable smoking and it had burned off about 6" of insulation from engine block back toward battery. ?? WHY would a Ground - wire get hot ?? connections were still tight -- I replaced the ground wire and attached it higher on the engine instead of the mounting bolt. Everything works fine now and the Ground wire isn't getting hot. WHAT COULD HAVE CAUSED IT ?? If he had not found it in time it probably would have burned up the mower as it crossed under the gas line. :confused2:
