My Toro recycler
Wmnutter
Hello, I went out to cut my lawn this morning and my mower would not start. I pulled the plug (spark plug), had no spark, purchased a new spark plug decided to check for spark before installing it and no spark. Do you know of any safety switch issue?
Did you purchase & gap recommended plug from owners manual? Do you have an in-line fuel shut off? How old is mower & what is model & serial numbers as well as all numbers from engine data plate. Check oil level & make sure to use fresh gas.
No spark is likely a bad coil or the blade safety lever mechanism/cable needs adjusting. Also check the ground for the coil.
