my throttle peddle/reverse peddle just went limp......
Jnj6370
  • / my throttle peddle/reverse peddle just went limp......
2014 Husqvarna Ariens 42” cut Briggs and Stratton regular mower not the zero turn. Ok, was mowing and all of a sudden it just stopped, blades still engaged Moyer running just no forward gear. Put it in reverse and it backed up fine, so I stopped to try forward gear again then nothing either forward or reverse. The peddle just flops, no resistance. I tried getting down low enough to try and see but being disabled I could get that far down.
Anyone have any good thoughts on this problem??? I hope it’s just a cotter key or nut came off something. Thanks ?
mechanic mark
you are probably correct loose or missing hardware. have a neighbor take a look.
