My new to me Snapper
DJayhawk
It's a model 3081 has the 8hp BS motor. I bought it today for $55 locally. How do you think I did? It currently does not run :( but hopefully I'll be able to fix that. This is my first project of this magnitude, so I'm going to have alot of questions as I move along.
Anyone have any tips to get me started?
Thanks,
Dennis
Well my starting plan is to just get the motor running. After that I'll start the process of restoring/repairing the mower.
I believe my model is from 1975 but I don't know for sure. Here is the Serial Number: 345877. Will that help determining when it was made?
For $55, that is good I'd say!
Good luck with the restoration, and I'm sure you'll get answers to any questions you may have along the way from the knowledgeable people here! :wink:
Ok so tonight I took the flywheel off to check the condenser and points and it's not there :eek: someone has stripped it off of this machine at some point. Luckily the parts don't seem to be too expensive does around $8.50 this sound right?
Also do I necessarily need this key switch?
There is one wire coming from underneath this plate that is not connected to anything I assume it might have went to a battery? Then there is also a wire coming off my magneto that is not connected to anything would this have been the other path off the battery?
Another problem I'm having is getting the main fuel jet nozzle out :mur: I'm starting to break the brass inside the slot. Any tips for getting this out?
That is likely the Kill switch... and the wire going to a magneto should Never be connected to the battery... When it is connected to ground it will kill the engine, When it is open it will allow the engine to be started...
:smile:KennyV
Thanks Kenny, I have two wires coming off the Magneto one of them grounds to the case of the motor, the other is loose. Any idea where it needs to go? Does it go to the Kill Switch?
Thanks
The loose one should be the kill ... should go to an engine kill switch... :smile:KennyV
So since I do not have the key for the Kill Switch do I actually need that switch?
Also does anyone know if my '73 8hp Briggs actually needs a condenser and points to run? Or does that have something to do with an electronic iginition?
