That's actually just a fabric cover and the wheels are really only on there so I can push the car around if I need to. When I get my garage built it's going straight onto a lift or a rotisserie. The car is a '77 Toyota Celica.
The Weed eater is still not running reliably. It'll run for 10 minutes and then stall, one primer pump and it will start again for a few minutes. I'll clean the barb again in case it's something that was in the tank that made it's way into the carb. The motor is pretty darn close to my old Honda, the only difference in the carb is that this one doesn't have a manual choke, and when running it's much less refined.
The othe rmower I picked up at the same time is a newer Murray made since Briggs bought them out and put their logo on everything. I unseized the engine gently and it runs, however the governor is in the crank case, not air and spring style like the older ones and it was seized, and not is sticky so it won't move on it's own. I'll either convert it to manual throttle or to the old style governor, but the body is almost flawless. I'll keep an eye out on the driveway where I got them because if they buy a new mower every year because of the neglect, then I can make a few bucks off of them. I have a good Quantum on another deck, so I may just throw that on the Weed Eater and deal with the Honda clone another time.
