Black Bart
Conventional oil will fail at 225F synthetic will continue to lubricate waay beyond that.Benski, Unless you can tell me of superior cooling with synthetic I do not see how that would have helped. Was using 10w30. The only damage to the engine (besides the cam) was a pushed valve guide which I attribute to overheating of the al head and /or max tolerances of components vs over heat. Motoman
This is the main reason I will not use anything but Synthetic in my air cooled engines.
