Black Bart
I use aYes but I don't remember where...:smile: Thks on the grats.
Motorcraft FL1a on my 1985 JD 180 and a FL910s on my Briggs in the Z.
You Kaw has a little different seal size but it is close try a FL910s and compare the seal against the oem filter and the filter base on the engine.
I think you will find it will fit and it is a better filter and can be bought at Wal Mart for 3.97 not the 12 or more bucks at your JD dealer.
Bigger filter a better filter and all for less $$$$$$$$
Enjoy your new GREEN MACHINE
