MurrayE500Prime 21”
Pulling the fuel hose off AT the carb inlet confirms two things, if you have a fat flow of gas.
1.Fuel tank cap vent is venting proper.
2.Fuel hoses, filter and a possible shutoff are flowing proper.
Starts but won’t keep running. Fuel starvation
Could be. Do the above test.
Might need a carb and fuel tank clean out.
If I press the primer button once or twice befit dies I can keep it running until it warms up. I can do this by clamping the throttle all the way open
Remove the air filter and housing. LOOK into the carb throat AKA venturi. Verify you see a small blob of gas jumping up vertically out of the bottom of the carb when you hit the primer bulb. If you don't see any gas, primer bulb needs some love. Sounds like yours is working a little. You hit it a couple times till she is warm.
Most of the time people over torque the air filter housing and the primer stops working. Or they have a bad carb gasket there or both. If the hosing is over torqued, need a new one or try doubling up on the gasket, carb to air filter housing. This is all about the primer bulb.
Looks like yours has the plastic Briggs carb. Many videos on how to clean one on youtube. Briggs carb part number 84002084.
