G ghostdad Forum Newbie Apr 10, 2012 #1 it will start if i jump the solenoid with screw driver whats up ?
R redkneck Forum Newbie Apr 10, 2012 #2 Sounds like you need a solenoid, or else you are not getting 12v to the solenoid.
Carscw Lawn Pro Apr 10, 2012 #3 ghostdad said: it will start if i jump the solenoid with screw driver whats up ? Click to expand... Run a jumper wire from the + side of battery to the small post on the solenoid if it cranks then you have a bad wire or a safety switch Sent from my iPhone using LMF
