murray riding mower
hlmorrison
The murray riding mower I have will not all even crank. In the wiring system from the wiring harness to the alternator wire the connecting wire has 3 wires and one of those wires is black which would indicate that might be a ground but I'm unsure of where it goes. Any help is greatly appreciated. Murray riding lawn mower model #309029X92C
Ok if it’s wiring on the engine you need to look up the model number of the engine. If it’s wiring to the engine then use the model number of the mower. If it’s not turning over at all. The there could be multiple reasons. Battery, solenoid, ignition switch, or any of the multiple safety switches.
hlmorrison
Hmmm, Ever thought about downloading the schematic? I could post it but I won't.
And that dang black lead from the stator is the AC output for lighting which this mower does not have so of course it is not connected. Someone with a poppy seed brain should been able figured that out by now but that might over tax it.
Oh well back to the dark side [just data collecting] and making parts while watching all the stupid relies to various posts. Just getting sore sides from laughing so much. Most here are just so called mechanics or just part replacers. And they are too scared to actually look up the equipment before replying. This is why I quit helping this forum. I am not going hold their hands and do the work for them without getting paid for it.
The stator only puts out AC and it’s not for Lighting. The stator puts out AC that goes to a regulator that charges it to DC to charge your battery.
jimbir
I see you've gotten a ton of replies. Let me ask a question then make a suggestion that has usually pointed me to the problem.
Question: Did it ever crank?
Suggestion: What happened just before it stopped? Did you do something?
