tigercat
No, Just the blades and the deck set up like it came from the factory.
Thank you for the answer. If my mulch plate is not working out for me, I will just remove it with confidence and mow / mulch like you are.
Leaves are the only thing we ever use Gator Blades for on a Scag. We put a mulching plate on and a set of mulching blades on and go at it. If you will raise the mower up and lower the front deck baffle to the lowest position it will help the blowout on the front of the deck considerably. You can mulch them down to a brown dust if you desire to.
High lifts are what we use to cut grass and Gator Blades are what we use for leaves. I have never had any success using Gator Blades to cut grass. We have 4 Tiger Cats.
I think I misled on the above. When I said raise the deck I meant to allow you to lower the baffle. You want to actually run it as low as you can to mulch the leaves. The lower you can run it the less blow out you appear to have and finer they mulch in my opinion.
Why not just buy some regular blades instead of ruining your gators?
We never run Gator blades for anything but cutting up leaves.
Good to hear!
I broke with tradition and just bagged the minor leaf accumulations on my lawns yesterday since they all have on-site disposal areas.
Have you tried the Gator G5/G6 high lift mulching blades? They're wider and discharge pretty well and have good lift. The carbide inpregnated edge holds up well too. The G6 are thicker and hold up really well but are heavy and take a well powered machine to spin them well. I originally used them but stepped down to the lighter G5s.We never run Gator blades for anything but cutting up leaves. We put the mulch plate on and lowering the inside front baffle helps on the blowout on the front of the deck. We run medium high lift blades to cut grass. Gator blades in my opinion are a waste of money to cut grass because if you cut tall grass, you need something that discharges better and they are made to shred and mulch in my opinion not discharge.
