Santa Chas
- Jun 16, 2016
- 4
To shorten the story I built this lawn tractor. Turned every nut and bolt on it. It is a 2007 MTD Yard Machines 15.5 B&S 38 inch cut mower. I am having two issues and cannot figure out the root cause.
Problem 1, BRAKES. Lawn Tractor wont stop. Took apart the brake assembly on the rear axle. Found the little pistons were frozen. The disc and the small pads looked okay and they were about 3/16ths thick and smooth as was the disc. Freed up the pistons, sanded the pistons and bores smooth and re assembled the brake assembly. Still don't stop. Not sure if this has the correct spring on it. It is not too hard to hook it up. Just a pair of vise grips on the end to pull it to connect to the rod is all I have to do and there is not much resistance. Should this spring be about 4 inches long and about 1/2 inch thick and the spring size be about 1/16th in diameter? Should this Lawn Tractor be locked in park with the brakes set? When I stop the tractor and put the lever in PARK, turn down the throttle and shut the tractor off when it is in neutral the tractor rolls freely. If I leave it in gear it stays in place. Is this normal?
Problem 2, Deck Blades. These do not ever stop all the way. Only on idle do the blades stop. Give it a bit of throttle and the blades begin to move. I have had the deck off and looked at the braking system on the deck. The pads hit the pulleys like they should. It appears there are two springs on this cutting deck brake system. One under the right blade pulley and another on the brackets near the middle right. In addition there is a spring that is hooked to the PTO cable and this is also hooked up (replaced the PTO Cable) and it works.
These are the only two issues I have. The tractor works superbly. This tractor was purchased cheap and needed some items fixed. One being a cracked in half dash on the lower left side. I installed a temporary plate to solve this problem but when I drove the tractor the hood always seemed to lean right. Another was the nose/grill piece was split by the two lower bolts. Craigslist netted me a parts tractor. It was a 2008 16.5 B&S 42 inch cut model which looked the same as my mower. I pirated the parts for my mower from the parts mower. Having nothing to do I decided to strip the parts tractor down to a rolling frame. Thinking it was time to install the good parts on my tractor I took mine apart. Well, upon inspection I found the main frame on mine was cracked in half by the foot brake pedal. So now both tractors got stripped down to bare frames and this huge pile of parts was gone through. The best of the best went in one pile, the bad in another pile. Every bracket, pulley, spring, nut and bolt, body panel etc was looked over and cleaned up. I re assembled the tractor and have been using it ever since with no issues other than these two. Since I never had one of these tractors new I do not know every characteristic of them so any help I would be grateful to get to assist me in getting this tractor 100% right. Thanks in advance.
Chas.
Here is a picture of this tractor as it sits now.
Chas.
