The real deal Briggs compressor makes things a bit easier.
The inlet & exhaust have different retainers.
One has a keyhole in the spring colar so you just compress the spring a little then push it back .
You can do this with a pair of long pointy nose pliers, or a couple of thick screwdrivers or the V end of a wrecking bar.
The other will either have a pin or regular collets.
You can work around, just depends on how much time you have and what sort of educational event you wish to make of it.
I always replace gaskets, they are about $ 5.00 for the head gasket or $ 15 for the full kit.
Just like a car head, start from the centre and loosen off the bolts 1/6 turn each in a criss cross manner then a second 1/6 th turn by which time ther should be almost no tension in the bolts.
I face down the ends of the valves with an oil stone.
It is a little tedious but you don't overshoot then have to machine down the seats which are a lot harder to compensate.
Briggs give you a clearence both with springs and without springs and I generally find the maxium clearance without springs brings fairly well in the middle of the clearence range with springs.
Good luck.
Good luck.
