MTD Pinto - 7HP Tecumseh Engine
jasonhibernian
Hi folks,
I have an MTD Pinto with Tecumseh 7 HP Enduro XL engine and I'm having a bit of difficulty with it.
It hadnt been used in a few years and was disassembled when I got it. It is back together for the most part and it will start and run but it isnt running 100%.
When I go to turn on the blades it cuts out.
(It's almost like it doesn't have enough power to drive them)
Has anybody got any info and would anyone have any photos of the spring set up coming off the carburettor?
Thanks in advance.
The model and spec numbers would definitely help us identify the correct manual to get you.
jasonhibernian
How's it going? Ok, we have it the set up sorted. The problem is the carburettor. Need a new one.
The engine details according to the label are TECUMSEH Enduro XL 7HP - 1951AC e11*97/68SA*2002/88*0353*00
Does anyone know where I might find one? Thanks
Those numbers don’t help. Take another look at your shroud, either stamped into the metal or on a tag saying model and spec.
jasonhibernian
Ok. Have you an email and i will send you photos?
Thank you
I don’t do emails, just post to your thread or send a PM.
jasonhibernian
Hi. I found another tag.
It reads - MODEL: OV195EA
SPEC: 23513B
