GearHead36
I replaced the needle valve. The old one looked good, but my eyes aren't good enough to see microscopic wear, and since I had a new one, I replaced it.Oh well I thinking the OP used the Stihl's gasket and diaphragm kit which has no inlet needle valve. It so it sounds like a leaky one that is leaking under fuel tank pressurization. If so then the OP needs the Zama RB-69 full carburetor repair kit as the needle valve tip is probably ringed worn.
