Mr. Technician
Rickengl
I have a scag 36" walk behind that keeps throwing the drive belt. Replace old belt and cleaned all pulleys and they all look to be aligned.
reynoldston
If I was to guess as to your problem I would say you installed the wrong style belt. Buy your belt from the dealer. If you have done so, you must have a pulley alignment or bearing problem.
If you have an OEM belt, I would check the bearings on the idlers as reynoldston said.
