gregjo1948
- Nov 28, 2012
- 75
- 362
Have an older Ferris Z with a 61"deck and a 27 hp Kohler. The left drive wheel is getting very close to not driving. It doesn't want to drive forward but seems okay backing up. Would it be the pump or the wheel motor? I'm thinking the wheel motor is failing because it does drive in reverse as it should so, if the pump was faulty, it wouldn't go backwards or forwards. Any thoughts???? thank you, gregjo1948
I tested the pump and found it to be working fine.
I believe the Ferris is an IS3000 model. and I'm looking for a Parker wheel motor TF0240UB080AAPX.
