Mower will not start :(
gamblemad
My John Deere LT155 needed new belts. I took the 38" deck off and changed that belt, I placed the LT155 on blocks got underneath the unit and changed the main drive belt. When I tried to start the tractor, the breaks no longer work and the unit will not start. I assume the tractor is not starting because the breaks are not operational. So I put the LT155 back on the blocks and removed the LS driving rear tire to see how the breaks are operating. I'm just not sure what to do next!
When you say the engine will not start, do you mean that the engine cranks but won't fire or the engine will not crank?
