schwanksta
I have a Murry 20" Classic mower with a 3.5 hp B&S motor that I rescued off of a trash pile a few years back. I showed it a little TLC (plug, filter, oil, etc.) and it worked well for me up until now. It starts perfectly and runs at idle, but it will not rev up at all. I pulled off the air filter and saw it was starting to crumble pieces into the carb, so I took the carb off and cleaned all of the little filters and parts I could find. I checked the gasket and cleaned out the gas tank as well. The problem persisted even after I put it back together. I pulled the plug, and it was pretty black (the plug is pretty new), so I cleaned it off. No dice. I cleaned the magnetic timing around the flywheel with sand paper. Same deal. I eventually pulled the new air filter back off and shot some starter fluid into the top of the carb. Instead of revving the engine up, it almost killed it. I think it's not getting enough air. Any ideas on how to fix that? I'm really not sure what to do next.
Any help is greatly appreciated.
Gene
Gene
