People,
MTD 13 HP rider mower, battery shows 12+ volts with meter, but no start. Did some checks with meter , may be even bad solenoid(again, only after 2 years!). But, when jumped with car battery, starter starts. Cant check the density of batt fluid with hydrometer cuz its a no maintenence batt- no caps to pry off. I think solenoid is still good as when I apply voltage to small wire at terminal, and key ON, cliclety click.
Bad batery? (low amps?) ASny way to check batery?
