Mower not charging battery
sven0777
Hello, I have a Gravely model# 991027 zero turn with a 21hp Kawasaki engine, with 250hrs on the machine. It will not keep the battery charged. replaced battery a few weeks ago thinking that was the problem, but I guess not. Any thoughts? Thanks!
Probably a bad stator and/or voltage regulator. Post the engine model numbers and I'll find you a procedure for testing, it you have a VOM.
Fish
Some of those Kawasaki systems had a fuse on their charging systems, I'll look at the Gravely schematic, but as Rivets has said, the numbers off of the engine are likely needed.
Fish
Well, this came up easy enough.....
