fred daniels
my 345 leaves a 1 inch strip between the right and middle blade. have installed new blades. pulley and blade shaft are all good. any suggestions. thanks
Did you compare the new and old blades side by side to see if they were the same size? Did you change brand or are they OEM? Just a thought.
Then you did not install the correct blades then.
Like gfp55 asked, did you install JD blades?
I think what has happened is one of the spindles has worn down. The bearings sit on a ridge in the housing. This ridge gets worn down and makes the blade sit lower or higher. Grab the blade and see if it has any up and down play. (Wobble)
If this is the case you will need to replace the spindle. Or you can put a thin washer between the bearing and the ridge. Either way your going to need new bearings.
What ever happened with your mower? Did you find out why it was leaving a strip, maybe you could let us know the outcome?my 345 leaves a 1 inch strip between the right and middle blade. have installed new blades. pulley and blade shaft are all good. any suggestions. thanks
