sillyboy
- Aug 20, 2011
- 28
- 90
Hi all,
After a valve adjustment, and 2 mowings, the starting problem resurfaced. I had to jump start it with my car last week. Starts great with a car battery.
Today (9-6-11) I readjusted the valves, but when I pulled the plug A LOT of gas came out of the plug hole. Looking back, I see that the needle valve might be leaking. Seems it is. How do I repair this?
I also think the battery is not being maintained thru the electrical system. Is there something I could look at here, also? It always sounds real weak even when it does start. When I turned it over, to get all the gas out and check the valve settings, the battery sounded as if if were ready to die again.
Thanks
Thanks
