I have a 1950s mow master lawn mower with a 2 cycle power pak engine. My problem is finding a coil for the lawn mower. I consider cutting the old coil off and replacing it with a small lawn mower coil.Any suggests would be most appreciative.
The lawn mower engine is odd ball design/maybe copied from a english version. The bell has inward magnets instead of outbroad magnets. The magneto is a bendix magneto with a clip on ignition coil/the coil looks like bus fuse. thank you for any suggests
