toddquick1977
I own an Encore Prowler commercial zero turn mower, with a 22hp liquid cooled gas Kawasaki motor. The mower will not start. I have replaced the following parts: fuel pump, starter, plugs, and PTO switch. I have checked the key switch and the safety switch near the e-brake. When we pulled the new plugs to see if they were firing, they weren't. HOWEVER, when we put our meter to the plug wires, we were getting a reading without the key being in the "on" position. When you turn the key to the on position, you can hear the fuel pump kick on. The motor will crank, but won't fire up. There is a very strong smell of gas when it is trying to fire.
I don't know what it could be, or what I should check next. Any ideas?
-Todd
Harrisonville, MO
-Todd
Harrisonville, MO
