Motor constantly floods.
Old sod
I hope some of you very knowledgable people can help me out
The motor is a Kawasaki R600v and starts and runs well until hot then floods and cut out. Full throttle to start again, engage blades and within 50m the motor floods and cuts out. ( all black smoke )
I had thought it was the needle and seat so removed the carby and cleaned and checked the float etc , cleared out the fuel lines and regulator, new filter, cleaned the tank and tried again. Ran sweetly for a while then the same, cleaned the carby again with the same result. With the motor giving me the same grief again I purchased a new carby and now the same issue only worse than before.
Question...could it be the fuel regulator not restricting the flow correctly and forcing fuel into the carby.
Any clues.
