turfboy1997
Looks like the problem is the governor spring. Although it looks hooked to the throttle slide and the other end is poking out of the hole in the boss on the adjustor wheel, the spring puts no tension on the vane assembly. If I move the vane manually towards me on the muffler side it just sticks. I tried rotating the click-wheel clockwise, when looking down on the engine, to try to get some tension in the spring but couldn't. You can see there's slack where the hooked end of the spring goes around the arm coming from the slide. By the way, I was asked before for the model and serial number. It's a 10323 serial # 220028437 which makes it a 2002 model I think.
No wonder it only ran flat out as the throttle remains stuck wide open no matter what the control is calling for. I'm trying to summon my courage to remove the carburetor assembly as I've watched videos of others struggling with the reinstallation. Any helpful ideas or just encouragement will be appreciated. Bob
There is a way to put those gov springs on upside down i think. you are going to have to take the whole carb apart to get it changed. if it is sticking wide open i bet it is running really fast too! take the shroud off when you do it because this will give you more room. you can do it! use the carb bolts to line everything up when you put it back together. the cup side of the vane is supposed to move right to left if you are standing at the handle of the machine.
