Mcculloch t26cs - Won't start
Make sure it is the right module
There are a lot that look very similar
On a mower it is not too much of a disaster but on a line trimmer that spin 3 times as fast that poofteenth off correct time can quickly cause it to go bang big time .
Also get a new plug
At compression pressures the fuel mix now days is almost as conductive as a wire so once a plug gets really wet the spark will run down the side of the electrode rather than jumping the gap because electricity & myself share a common characteristic,
We are both lazy & take the easy way every time
Hi,
Just like to say thanks for your help and advice... replaced the ignition module and it started straight away. Only downside is I've got to use it now :-)
Thanks again.
Mick.
