Mcculloch 170AWFPX ?
Michael72
Hi all
Newbie here... just said a quick hello in New members Area...
I recently acquired this machine and if im honest pupil dilation in terms of its appearance was the main factor :rolleyes: Im a small engine mechanic so any engine issues is not a major issue for me as such..This machine has the Rato engine which I have never worked on before but by the sounds of it- its a candidate for fully synthetic....run well, powerful.. 3kw @ 2,900 RPM which Ill increase to 3250rpm when mower is run in...
Early observations/ moans is the dipstick... extensions to the back wheels...these steel brackets seem very weak which cause the back wheels to splay... I guess this helps mobility somewhat but when the box is full of damp ish grass it could be a different story!! :smile:
Any thought, tips etc most appreciated ...
Michael72
Hi
Have it but thanks...I'll see how it cuts before I change those brackets...simple job if needed thanks..
