Shughes717
35 hours on mine. Failed to start once, would not even crank over, ended up having to jumper out the solenoid so I could get it loaded and get home. Never failed since then, go figure. I did notice the back side of my deck belt looked a little roughed up, found the idler pulley sitting at an angle due to a loose bolt. Hopefully it has not hurt the belt very bad. I still think my cut is not too great, got to run really slow to get a good smooth cut, dandelions it knocks over if not going slow.
Dandelions are not easy to mow. The stalk lays over too easily. Spraying to kill dandelions and clover in the early spring will save you a lot of grief when mowing. It rained so much here that I didn't get a chance to spray mine and I had 4 acres of solid dandelions. I mowed my lawn lower than I have since I have been at my new home and it did ok (2.25 "). There are still several standing back up, but it looks much better than it did. I hate mowing that low, but I needed to do something. I still may spray my lawn this weekend.
