Mower deck LX280 ENGINE STOPS WHEN ENGAGING PTO SWITCH
CAPTAIN BUDDY
I BYPASSED THE SEAT AND BRAKE SWITCH, WHEN I ENGAGE THE PTO SWITCH THE MOWER TURNS OFF
Does this model cut in reverse ?
If not you got another one to try.
Now the brake switch has 4 terminals, one pair need to be bridged while the other needs to be open.
JD wiring tends to be a little over done.
shiftsuper175607
You can't bypass them both at the same time. I did that and had your problem.
Evidently something has to reset in the interlock circuit board. And that is prevented by having them both bypassed.
That's my opinion.
