I BYPASSED THE SEAT AND BRAKE SWITCH, WHEN I ENGAGE THE PTO SWITCH THE MOWER TURNS OFF
C CAPTAIN BUDDY Forum Newbie Joined Apr 16, 2015 Threads 4 Messages 4 Apr 16, 2015 / LX280 ENGINE STOPS WHEN ENGAGING PTO SWITCH #1 I BYPASSED THE SEAT AND BRAKE SWITCH, WHEN I ENGAGE THE PTO SWITCH THE MOWER TURNS OFF
B bertsmobile1 Lawn Royalty Joined Nov 29, 2014 Threads 64 Messages 24,745 Apr 16, 2015 / LX280 ENGINE STOPS WHEN ENGAGING PTO SWITCH #2 Does this model cut in reverse ? If not you got another one to try. Now the brake switch has 4 terminals, one pair need to be bridged while the other needs to be open. JD wiring tends to be a little over done.
S shiftsuper175607 Lawn Addict Joined Sep 11, 2013 Threads 10 Messages 1,000 Apr 16, 2015 / LX280 ENGINE STOPS WHEN ENGAGING PTO SWITCH #3 CAPTAIN BUDDY said: I BYPASSED THE SEAT AND BRAKE SWITCH, WHEN I ENGAGE THE PTO SWITCH THE MOWER TURNS OFF Click to expand... You can't bypass them both at the same time. I did that and had your problem. Evidently something has to reset in the interlock circuit board. And that is prevented by having them both bypassed. That's my opinion.
