Pulled an old LX188 that's been sitting idle for years out of my father's garage. Went through the basics and got it running again (plugs, oil, battery, etc). Drove it for ~20 minutes and everything was fine. When I went to use it a day or so later, the key had been left on. Put the charger on it but it still wouldn't fire up. Put a spark tester on and there's 1 small, faint orange spark when I first turn the key, then nothing.
From what I've been able to find online about these, it's usually one of three things that's failed: the regulator, the ignitor, or the coils. The problem is that I've tested resistance on all three, along with the pulser and the stator coil terminals, and they're all off from what the Kawasaki charts specify. I don't know if everything got fried when charging or if I may have gave it too much battery with the new one I put on. Or maybe the specs from Kawasaki are just off? The battery is putting out ~11V so it leads me to think it's most likely one of those three items.
Anyone been down this road with the LX188? I'd like to figure out what caused the issue before I just start throwing parts at it, and the one I'm leaning towards (ignitor) is the most expensive of the three. The Tech Manual just doesn't interest me @ $125!!
Thanks for any input!
