Greetings from down under. First time on the forum.
My problem. I start the engine, increase the revs. pull the switch and the blades rotate. Mow 100feet or so and the blades stop. No sign of smoke or screaming from belts running on jammed pulleys.
Closing and opening the switch has no effect. Leave the machine for 2-3 hours, (Like let it cool down)
Restart it and mow another 100feet and the problem reappears.
Any suggestions on what is causing the problem the problem would be much appreciated.
PS it's a 1998 model and had seen a fair bit of work before I purchased it 3 years ago.
