LT155 will not start
spinmiester
I have a JD LT155 mower that will not start . Mower would not start so I tuned the mower up changing oil,sparkplug gap at .40,air filter,fuel filter. Mower started and mowed complete lawn, as I was putting in garage mower quit and will not start.
Can you post the model# and serial# off the engine?
Do you know if it has spark? do you know how to check for spark? I don,t know your skill level, so don't take things I say wrong. Check to see if the carb is getting fuel, If you are getting spark and fuel, You need to check the safety switches like under the seat, the clutch/brake switch,etc. Check the fuse behind the dash. Do that stuff first and if those don't help post your findings. Make sure the battery is good and charged also.
