lt 160
jamie keeton
lt 160 after about 5 minutes of running the engine fills up with gas in the oil. how could this be with it still running
mechanic mark
Cannon51
When I bought the LT160 I have it had gas in the engine. After changing the oil and filter it ran fine but would have gas in the oil again the next day. After fooling with the carb a while I figured out that the mechanical Fuel pump was bad and allowing gas to go straight into the engine. I changed it to one from Stens or Rotary and have had no more problems. Just something else to consider.
Cannon
